1 - 20 of 73 Posts
Things to do
1. Replace Pwr LED + HD LED with white 3mm Leds
2. Make a windows on my side panal
3. Further modify my modified PSu to fit the Case better (+ add support for 17V line (To over clock fans) & replace Blue LED
4. Replace the leds on a red 200mm fan with white LEDS
5. Add Cold cathods
6. Run all wireing to the cold cathode switch Rocker switches
7. Replace the LEDS on the Sigma power supply.
8. Replace Keyboard / speakers / mouse LED's
*9. Sleeving
I already have half of these mods in motion and the other half is awaiting funding.
I expect to spend about $50 (Really arent expensive stuff to do)
Progress
Done:1, 2, 3, 4, 5, 7, 8, 9,
Not started: 6*** Next Major update ETA March 2011
[/IMG]
As of Now
looking good.Boy is that one CLEAN cut!
Discussion Starter · #12 ·
Originally Posted by M1nUrThr3t View Post
very very nice. What did you use to make those cuts? Very clean.
off topic, do you know the estimated delivery date for my case?
I used a Jig saw then cleaned the edges using sand paper and a filer.
I dont know check Paypal i left a tracking number there. I believe parcel says any where from 7 - 9 days..
check tracking number...
Sigh*
I did drop it off the 12th. So i can guesstimate it will be there next Tuesday - wednesday
cool thanks.
I like what your doing with the cathodes. I would say if you could paint the interior of your case black and have the white lights, my pants would fit tighter.
lol
Discussion Starter · #17 ·
Regular jig saw. Yes alittle bit of paint came of on the most acute corner of the cut.
How ever im getting some molding to cover up all the edges. Im just waiting for it to come in the mail the side window might be the first mod finished.
**I also added another part to this project which is sleeve'ing. Except im going to do it on a budget. So basically im only going to sleeve the parts that show. Im excited to see how thats going to turn out.
1 - 20 of 73 Posts
