HAF 922 fan placement..
683 Views 5 Replies 4 Participants Last post by  allenkane
two 120mm @Top (Exhaust, custom at rear and stock at front
one 120mm @rear (Exhaust, custom)
one 230mm on side (intake, stock one)
one 200mm on front (intake, stock one)
That should be good, right?
1 - 6 of 6 Posts
Sounds good to me. Should keep all your components running cool
Sounds good to me, not sure if the 230 will fit on the side though and what custom ideas do you have for the top and rear?
Chad
Woops. It isn't a 230mm, it's a 200mm. The HAF 922 comes with two (2x) 200mm fans and one 120mm fan (rear).
two 120mm @Top (Exhaust, custom at rear and stock at front)
one 200mm on side (intake, stock one)
Custom ideas?... Mmm... I don't have any =] Might just aswell buy some coolermaster/tricool fan and put them there.
how bout the one in the bottom? should it be intake? or exhaust? or do you guys even put one?
It should be intake. Generally the bottom fan will help with GPU cooling.
1 - 6 of 6 Posts
