1 - 6 of 6 Posts
I'm planning on getting a haf 922 with blue LED's. But I don't want the LED's to always be running, so how can I turn some of them off when I want to? I read that there's a button on the case that turns off the front LED, but are the other buttons for the other LED's?
I don't want ALL of them off at ALL times, just some of them off sometimes
Not sure about the buttons that switch off leds. But you could simply drill a few holes in the back/front of the case where u can add buttons that can turn the leds on or off. Mind you that you will probably be having a acble mess in ur system.
I have the red led version of this case. The button on the top only controls the front fan in my case. I looked at the picture and there does not appear to be a separate wire to control the other fan led's so the other fan led's will run all the time. Its a great case, has excellent airflow and the lights are not overpowering. Hope this helps.
1 - 6 of 6 Posts
