HAF 932, 800D or TEMPEST EVO?
3954 Views 44 Replies 28 Participants Last post by  Metal425
hi guys, i am considering these three cases.
first is the cooler master HAF 932
http://www.coolermaster-usa.com/prod...roduct_id=2810
second is the NZXT Tempest Evo
http://www.nzxt.com/products/tempest_evo/
thrid is the Corsair 800D
http://www.corsair.com/products/800d/default.aspx
now i cant decide which one to get. my rig would most likely be air cooled but i dont want to restrict myself if i have addition money for liquid cooling. i would like a case that has the potential for liquid cooling also.
also, i am open to other suggestions of other cases. but i must have an acrylic side panel. and potential to liquid cool as mentioned above.
thanks in advance
1 - 20 of 45 Posts
Easily Haf-932. Best of both worlds in my opinion. If going strictly watercooling then it would be a different story, because both the Haf-932 and Corsair 800D do an amazing job at watercooling. Haf-932 has great air cooling as well as room for watercooling. The fans are large and quiet yet move a good amount of air. You can go 120mm fans as well and they do a great job as well. Have had my Haf-932 for 7 months and its easily the best case I've owned yet. 800D doesn't have that great of air cooling, but it's great with watercooling. In my opinion if it was priced a bit lower it would be a good buy, but for its price range I think I can find a little better.
im useing the haf 932 and its a very good case but if i changed this i would definately get the corsair 800D
dont get the 800d unless you are 100% sure you will go WC. Otherwise temps will fail
why will temps fail ? if not watercooling.
It has horrible air cooling. Haf-932 is much better if your going to be doing both. 800d in my opinion is overpriced.
so basically the haf 932 has better air cooling than the 800D?
but in terms of water cooling? which is better?
The 800D is better for water cooling, not many other cases are.
They are pretty much even. Both have huge interiors and both are excellent in watercooling.
First of all, consider the price difference. Do you really want to spend $150+ more for the 800D? If you've already invested in water cooling, then the answer might be yes, although I think it's highly overpriced either way.
HAF 932 can accommodate a water cooling system very well at a good price, but it does the same for air. The 800D is only good for water cooling.
Well If you had the interior of the HAF932 powder coated black then the difference betweeen the HAF and the Corsiar 800D neglible. I have had both and think the fans in both suck, I replaced all the HAF fans and I will replace all the Corsiars fans. I am going to remove window and replace it with mesh. The windows is attached with threaded rod welded to the side panel. I will then add fans to the mesh for the video card. Honestly I would rather have no fans included with higher end cases because I rather pick the ones that I use, I realize people would complain but I rather have $25 that fans that go in a spare parts bin. I like the Corsair over the HAF932. When the 932 came out there was a lot of negative feeling towards it and now its very popular, the 800D may never be as popular because its more expensive but it is powder coated where as the 932 isnt.
Well If i were you I would jump and order a HAF 932 for 85 AR with promo code EMCMMNV35 http://www.newegg.com/Product/Produc...L0G-_-11119160. Only today though! Or if you wanna wait I would get the Tempest Evo, it has a nice black finish, tons of fans, nice cable management and a nice big window. Plus it's only $109 on newegg. http://www.newegg.com/Product/Produc...-062-_-Product
Yup, ordered mine today for $85 as well. The Corsair is nice, but if your not watercooling, then theres no reason to spend 300 bucks on a case that isn't good for air. Plus, if you're really picky about the inside color, you could take it to a local store and get it powder coated for probably $50. And if you buy it tonight and get it powder coated for like 50 bucks, it's still just $135 which is still cheaper than what it normally sells for.
Weston
what does having the interior powder coated do? Not dissing, I just don't know other than it doesn't scratch easy, I can see why on bicycle frames, but curious to why inside cases.
Personal taste mainly. It just gives the interior a different color.
If air cooling, go for the HAF932. For water cooling, the 800D can't be beat with its design for water cooling.
that's what I figured...unless some knuckle-head can show me some graphs for increasing airflow. What next heat treating?
id give my first born for the 800D.... ok not the best airflow but it has some awesome features and is really a work of art
1 - 20 of 45 Posts
