1 - 14 of 14 Posts
Well this is my first custom watercooling build
I want to add a tri rad to the top
the problem i have is i dont know what fans to use where without the problems
this my first large build and my first water cooling build
where can i put the fans ?
I have 5 noctua fans 2 akasa led fans 1 coolermaster tri led and 1 antec ltri led all 120mm i dont know where to put them,
I also have a 2x 200mm coolermaster fans 2x
220mm red led fans 1x 140mm
I will be putting in a tri rad at the top
should i change the top fans from 2 coolermaster 200mm to 3x 120mm or something else
or keep the 2x 200mm and also add 3x 120mm fans to the rad
ive been told for best cooling have the top and front as intake and side back as exhaust
what would you do ?
Too Poor For This
Remove the 200mm fans and replace them with 6 120mm fans in a push/pull configuration (Three on each side). Have the front as intake and the top as exhaust that way there is an actual flow direction from the front to the top. Also you should have the fan that's in the side panel set so it's blowing air into the case.
so the 200mm fans are no good ?
also the front and back fan intake or ??
Too Poor For This
For a radiator the 200mm fans are no good. For the front have it as intake like it already should be. The back really doesn't matter much. If you want throw a 120mm fan as exhaust. That way you have air coming through the front and side panel and out through the top and top rear.
I have a haf x that I'm thinking about doing my first water cooling rig... subscribed.
Sent from my SCH-I500 using Tapatalk
will the haf-x stay quite ?
I'm doing my first WC loop in my HAF-X and i plan on putting a RX360 in the top with the stock 200mm fans on top and 3 gentle typhoons underneath in push pull. I also plan on sticking a RX120 on the exhaust with a gentle typhoon in push.
Discussion Starter · #11 ·
ive already got the rad, Im just looking at the best option,
keep my pc cool and quite
Too Poor For This
Originally Posted by BKsMassive;11926087
Cooler master R4's move 70CFM
CM 200mm fans only move 110CFM
you can have 3 120mm on the top
so it's 110CFM vs 210CFM
Uhh no, CFM doesn't matter as much as static pressure.Not to mention a good bit of that air doesn't even pass through the radiator since it's too wide and it will just be hitting the side of the radiator.
1 - 14 of 14 Posts
