Thanks but i would like a fan controller, a blu ray drive and a dual bay res so I heard that the 360mm rad wouldn't fit because you need the top 5.25" bay free. Is that true or can I just take out the hotswap?Originally Posted by ttoadd.nz;13107829
it will fit easily. Use the existing fan screw holes to mount the rad and fans to the case. Go with a 360 tbh, fits perfect.
Check septro's build log. Has everything you just mentioned.Originally Posted by Cheddar97;13107844
