Dear community,
after some people helped me out, because I am a noob, to choose from
watercooling parts for my new pc i´ve bought the following:
Case: CoolerMaster HAF-X
CPU: Intel i7-3930K (actually only at 3.8 Ghz, if i need ill put it up to 4.5)
MB: Asus Rampage IV Extreme
RAM: 4x8GB G.Skill 1866 Mhz CL8-9-924
VGA: 2x Asus Geforce GTX 680 4GB GDDR5
PSU: 1200 Watt Enermax Platimax (80+ Platin)
SSD: 256GB Samsung 840 Pro Series
HDD: WD Blue 1TB
OD: LG BD-Rewriter
Fancontrol: Aerocool Touch-2100
Radiator: Alphacool ST30 360mm (Push/Pull with Top/Radiator Fans)
Pump/Reservoir: Dual Laing D5 Station + 1x VPP655
WB: EK-Supremacy Elite - Intel 2011
Tubing: XSPC 19/13mm Blue / UV Blue
Fittings: XSPC
Drain valve: Koolance
Coolant: EK-Ekoolant UV BLUE
Fans
Top: 2x 200mm Coolermaster MegaFlow Blue LED
Front: 1x 230mm Coolermaster MegaFlow RED LED
Side: 1x 200mm Coolermaster MegaFlow RED LED
Rear: 1x 120mm Enermax T.B.Vegas Blue
Radiator: 3x 120mm Enermax T.B.Apollish Blue
Lighting:
2x 10cm Sharkoon Cold light red (a little pink, but its okay, no one of them is perfect)
-> placed in the third of 5 HDD shaft
1x 10cm Sharkoon Cold light blue
-> placed directly in the reservoir (there is a shaft pre-done of alphacool for it)
Monitors: 3x 24" Acer S242HLCBID
Mouse: Mad Catz R.A.T. 7 6400 DPI
Keyboard: Mad Catz S.T.R.I.K.E. 7
Mousepad: Razer Goliathus Speed Alpha
Headset: Razer Megalodon
Your opinions on this case? And could you give a tip at how much GHZ
i can overclock my CPU?
Greetz, Alex.
HDD: WD Blue 1TB
OD: LG BD-Rewriter
Fittings: XSPC
Fans
Lighting:
Greetz, Alex.
