1 - 10 of 10 Posts
Really liking the look of this case...even considering the NV Version to match with a new Assassin MB.
Q: Would I put my 2 Raided SSD boot drives int he front hot swap bays?
I seem to see only one SSD tray mount in the internal bays!.
Thanks...
· PC Enthusiast
The front bays have mounting holes for an SSD, but I would not put Sata3 SSD's there because of the adapter used in the front bay messes it up
Originally Posted by MIKEVALL;12969728
only one in the side trays, but your ssd will come with one!
Ps. im lovin my HAF-X Made my build a breeze with all the great features it has!
No, my SSD drives were from a shop built buy. No attachments. ATM they just sit in my case slots buy themselves
Thanks...
Just go down to your local Computer store an buy a 5.25 in to 2.5 in adapter, it should be cheap as it's just pressed or stamped metal sheet.
Make sure you get the right screws with it.
Sorry to threadjack, but what do you mean the front bay adapter messes them up...should i move my ssd to one of the internal bays?
· PC Enthusiast
well, messes up is probably the wrong word, but I know that if you use the adapter when trying to update the Firmware, it is a slim chance it may brick the SSD, so something must interfere with the SSD's when having that adapter connected
1 - 10 of 10 Posts
