Hey All,
So I bought a HC-500A, plumed it up as below:
D5 Pump/Res --> HC-500A --> RTX 2080Ti Waterblocked --> 9800X Monoblocked
All works fine, I set a few degrees above dew but regularly monitor dew point in the room.
Now, because there is such a small volume of water in the loop (about 5 -6 liters) I can see the heat soak very quickly.
Not to mention the compressor having to work very often.
I am aware that introducing a tank of water of some sort is the answer here.
Looking at the specs of the HC-500A I need a tank capacity of at least 200L to be within "efficiency range"?
So I am assuming this is the solution:
D5 Pump/Res --> HC-500A --> 200L tank --> RTX 2080Ti Waterblocked --> 9800X Monoblocked
Am I on the right track here?
