On the Entanglement level there are a few points where you have to set up turrets. My problem is I can get them to go off when combines are near them. If I walk near them they go off but even if i block both entrances on the first part and put the turrets behind them they do not go off even when a combine is right in front of them. Is this a bug??I got past this part by blocking the sairs and picking them off with my magnum from one of the balcony's. But I'm now at the second part with three turrets and just cant do it. I block them in with crates and place the turrets behind them. Then I hide In the turret holders. But the turrets just dont go off. Am I doing something wrong. Also how do I pick up the turrets when they are knocked down?? if i use the gravity gun it picks them up on their side then drops them on their side......confused I am !!!:swearing:
This must be a bug. I never had the problem. They are supposed to activate and shoot the combine. When the turrets fall over it's tricky to get them to stand back up. I just shoot them up in the air and try to catch them almost near vertical.
I've had that level bug out on me before as well, but instead Alyx simply never showed up once the fighting was over. Just re-load a save at some point before that level and hope for the best.
just sit back in one of the little holders for the turrets. keep the combine back with grenades and such, and just jump out and shotty then every now and then. should be able to pull it off.
If loading an old save doesn't work, re-load the level, press ~ (enable dev console in keyboard advanced options) and type "map " and then press down arrow till you get a level name that sounds right. I think it's prison.
This will start the map completely over, so it should be alright after this. Or also, right click hl2 in steam, properties, and verify files.
That sux.
BTW, you can pick up the turrets by hitting E if I remember right. Haven't played in a while.
That's my favorite part of the game. Total chaos.Turret goes off run there to kill Combine. Other turret goes off run back. run back and pick up the turret that got knocked over and repeat. I love that.
Overclock.net
