Hammer Time! Pics included!
1531 Views 23 Replies 16 Participants Last post by  Sickened1
8
Here we go....
Nice packaging as we can see.
comes with the new back plate that fits both 775 and I7, it also comes with
the usual stuff like the rubber mount, screws and the amd bracket etc.
craftmanship is flawless, black nickle finish.
Another clooser look, very complicated fins layout and looks really good and high density.
Massive HDT heatpipes, don't know what the center piece is for but it looks nice.
another closer looks to the base design, looks very solid.
installed it with Ultra Kaze, it fits on xfx 780i mobo and it is touching the memory heatsink, no big deal cuz xiggys rubber fan mount really good at absorbing vibration.
HERE IS THE KICKER! forgot to put the exhaust fan back in place, have to tear the whole thing apart..............sigh.
1 - 20 of 24 Posts
Nice, how are the temps?
nice fan
hate exhaust fans. Pain in the a**
Originally Posted by Spectre21
nice fan
I haven't done any long test yet just fired Prime 95 up for a bit to see, I can tell you it is quite significantly better than the RS1283, will run long test after I reinstall everything!
The temp's are amazing on this thing. It's running much cooler than my old S1283
Poohball mind if I post some of my own pics?
I wonder what xbitlabs will say about this cooler once they do their review.
I think I want your 5D Mark II more.
Anyways, sick cooler.
Surely I can't be the only one who entered this thread with expectations of seeing computer parts being smashed up?
Hmm looks like the base is solid with the pipes exposed? Do you have any shots of the base?
EDIT:NM i can see now you still had the protective cover on it.
If you didn't have the tall heatsinks on your memory, will the fan still be hitting?
I want this cooler but I might have to switch my memory first.
nice, i like the looks of it. post your temps when you get a chance.
Not at all. I was thinking the same thing lol.
Originally Posted by poohball
Here we go....
the usual stuff like the rubber mount, screws and the amd bracket etc.craftmanship is flawless, black nickle finish.
looks like wires and fans hanging off every where....what temps do you have there ?
If you have tall heatsink's you can use them in the first slot but ONLY if your using a 25mm fan. Anything longer and it will block out your first DIMM.
Crazy fin design.
me 2
Thanks for responding.
I have 2 Panaflos that I want to use in a push/pull config and looking at poohball's pics, he had to "open" the memory clips to make it work. Looks like even if I had memory with regular heatsinks it might not still fit? Hope you can clarify.
Thanks again.
Thanks again.
Well if the heatsinks have tall fins on them like the Corsair Dominator dam does, then you can't fit anything over 25mm. If it just has the heatsinks that sit on the modules and don't have fins that jet upward you might be alright.
Please do =) we are here to share!
1 - 20 of 24 Posts
