Which should I spend my $600 on??
  • Second 5870 video card
    Votes: 22 34.9%
  • Water cooling setup for my rig
    Votes: 41 65.1%
1 - 20 of 53 Posts
I will soon have around $600 (Australian) and I was originally planning on purchasing a second 5870 but am now torn between getting the second 5870 and watercooling my rig as it is now, so I have decided to start a poll, should I get a 5870 or watercool my rig (Including my current 5870)??
Originally Posted by Gizmo View Post
Get wet. 5870 will thrash just about anything at any res you'd be using anyway.
I WOULD have done that but I left out one detail: I will be unable to spend all too much money for the next few years as I will be going into uni and I'm not sure i would be able to affort too much for my rig so I would in all likelyhood have to make this last for some time.
I can get 4Ghz with HT on, it gets a little toasty since this is a C0 and needs about 1.45v to do it, but because I dont use LLC I feel safe running it 24/7 and as for the 5870, I haven't got around to trying anything other than CCC to OC it so i can hit 900/1300 which is the max it will allow.
Watercooling the cooler the longer lasting you can add another card later when nvidia launches Fermi the prices will be lower for hd5870.
Discussion Starter · #9 ·
Really my only problem with going on water is that if i want to add another card later I might not be able to afford to, but, on the same note, I have also considered scraping together some extra cash and getting a second 5870 and watercooling everything too, I'm just not sure if I'd be able to get the money together.
You've got an i7 rig, dual monitors, 12 GB of memory, a Noctua cooler, and a 5870, yet you're worried about getting money together...oh how ironic.
Honestly, people still don't need that second 4890 to run most games. I still say water.
well heres something which should give you a fair idea what to start with..
Id personally go with something like this
*CPU block- swiftech apogee XT (personal vote goes to heatkiller 3.0 tho)
http://www.petrastechshop.com/swapxtcpuwa1.html
*Rad XPSX RX360 or a Swiftech MCR-220 Rad
http://www.petrastechshop.com/xsrxtr12ra.html
*tubing Masterkeeler 7/16ID 5/8 OD
http://www.petrastechshop.com/7id5odmagepu.html (1/2) barbs required*
*pump D-5vario (i linked, or a 355)
http://www.petrastechshop.com/swmcin12pu.html
*Reservoir Swiftech-Micro Res
http://www.petrastechshop.com/swmcmirere.html
As for coolant go with plain distilled water and possibly some coloured tubing, as some dye can really stain your tubing, LOW Cfm fans for the XSPC rad, if i missed anything pm me
Discussion Starter · #12 ·
Yeah, the thing is that I bought those parts with money I had saved over some time and now I will be able to only really do one or two things before I really need to save up for uni, so, in reality this could be it for the next 2 years, which will honestly be really dissapointing as this is pretty much the only hobby i have found that i really enjoy. I am really leaning towards the water though, plus, it will be more enjoyable to experience than getting another graphics card.
Discussion Starter · #14 ·
Thanks for those, I am gonna have a look right now to see what i can source easily over here.
Discussion Starter · #15 ·
I think I may be sticking with the single 5870 and going under water, unless i can get some extra work over the summer in addition to my current job, then i might get both before i start saving for the rest of the year.
Edit: Sorry for the double post.
Im on high end air right now but if my case allowed for it, i'd probably go to WC. (what i voted)
Given that limitation my next upgrade will probably be a SSD, have thought about those in an upgrade. SSD's are like the new "ram" for most noticible upgrade
Water cool it dude! that 5870 is gonna do ya for the next 2 years at least. Think of the fun you could have cooling that beast of a rig you got!! Sort those temp troubles out!!
Discussion Starter · #18 ·
I really think I am going to go down this path... once i get the money of course... and considering there really isn't anything that this card struggles with... can you say Crysis: WH maxed with 2xAA??
... I guess i really should be set for a while in that department
So i might go down the WC route... especially considering that summer is comming on fast over here.
Plenty of room in that 1200 aswell, Good luck dude
Discussion Starter · #20 ·
Honestly, I would really love to go with water but there is still a little nagging voice in the back of my head telling me that its not going to add performance like a second 5870 will... but on the other hand i wouldnt really use that second 5870... it's just really daunting thinking that this could be my last major upgrade for years, I really dont know which to do lol
Edit: As a hypothetical, if I DID water cool, what kind of setup would I be looking at to cool my i7 as well as my 5870 and possibly a second down the line?
1 - 20 of 53 Posts
