Hard drive fail, please help fix
586 Views 15 Replies 6 Participants Last post by  n1helix
I have a 500gb Seagate HDD and it stops my computer from booting up even to the bios screen, I can hear my fans accelerating and decelerating. Right now I'm using an old IDE hard drive, but I would really enjoy having the 500gb back without having to buy one. I've only had it about a year too, so it shouldn't have given out yet. This problem started after I shut down my computer one day improperly. It just won't let me boot up, and sounds like its stuck in a loop. Other hard drives work fine though, so I know its just the HDD
1 - 16 of 16 Posts
RMA the drive, it should still have warranty
Is it the 7200.11 drive?
It's possible for SpinRite to repair it, a wonderful software that I highly recommend buying.
Yes it is
Yes it is
A while back there was this huge firmware issue with the 7200.11 500 GB drives. The drives would just stop working. Well, Seagate finally released new firmware for it claiming that it was the solution. But it wasn't a solution at all. For many people, it didn't make any difference. This is what I often refer to as "the 7200.11 firmware debacle" because it was just ridiculous.
Unfortunately, that's all the information I have on that. I don't know whether or not there is a true fix or not. If there is a fix, then I don't know how to get it or what steps to take. But I do remember that many people were being forced to send their hard drives to Seagate to have them fixed once and for all.
Yeah, that sounds like something completely ridiculous that probably happens a lot. I'm going to try spinrite like another poster suggested though, before I go into sending it back
Right on.
But that firmware issue was a rather isolated incident. Seagate seems cool again now. I think they got redemption with the 7200.12 drives.
yea i own a 1Tb external HD, i ran hard drive sentinel and 40% health
i checked and mine too is a 7200.11 im going to call up Seagate on monday and ask for a new one
There is a fix - google "7200.11 firmware mobile phone cable fix" and something should come up.
You modify a mobile phone serial cable (from eBay for ~$5 or so) to fix the drive - the procedure appears pretty simple, but I have not done it myself.
Personally I would not trust the drive even after you update the firmware, because their controllers are crap. But others seem happy with them - your choice.
But this only affected the internal 500 GB 7200.11 drives.
hmm...if it won't POST it ussually means the hard drive (or some component) needs to be replaced.
If it is repairable, a checkdisk /r would find out as well.
You can do this with the Windows 7 disk. Just boot from the CD and select the repair option instead of the install option. Then under the command window option type in:
chkdsk c: /r
replace the c with what ever drive letter you think it is.
In XP and Vista this same little command will fix a lot of boot errors. Though I haven't had any luck with it in Windows 7. it will take a while to run, just let it go.
did it?, i read somewhere that there we like 21 hard drive affected, even the free agent which i happen to own
http://www.anandtech.com/weblog/showpost.aspx?i=540
If you opened up an external drive you voided the warranty - Seagate may not replace it.
The drives they use in externals tend to be lower binned than those sold at retail - it is usually better to buy an enclosure & a separate drive. This gives more warranty & better troubleshooting, repair & recovery options in case of a failure.
Oh, alright then.
i never did open it though, im not that stupid as the drive came with a 5 year warranty, ive had it exactly a year because i remember buying it on black friday last year
hopefully seagate will help me
1 - 16 of 16 Posts
