So, I recently installed a second hard drive, got it all hooked up inside the case,etc. How do I actually make it so I can save stuff onto it Windows?(As in, it doesn't show up)
There should be a section on the second hard drive that says "Unallocated Space" or something like that. Right click, and click New Simple Volume. Allocate all the space and perform a quick format. There you go. Windows should be able to see it now.
I am having this exact problem. However when I right click it the only option is "properties" and "help"...the other choices are grayed out.
*Got it...missed a step. Thanks!
1 - 6 of 6 Posts
