1 - 12 of 12 Posts
Around the beginning of this week I thought I was seeing things as my hard drive space kept getting smaller and smaller without me downloading almost anything, but now I know its not me.
When I got home today I noted that my hard drive had 122GB of free space (about a little less than 7 hours ago). After playing R.U.S.E. and Bad Company 2 for a while I decided to take a brake and saw that I now have only 106GB of free space left.
What on earth could be going on here?
Thanks for any help
Try looking in the C:\\Windows\\Temp folder.
Originally Posted by wiggy2k7
system restore points maybe ???
i second that, check you system restore points....
Turned off system restore then turned it back on. Restarted PC. I have 107GB now, there has to be something else...
Discussion Starter · #12 ·
Originally Posted by Platinum
Might be the VSS, check the guide here to reduce the size. The procedures are same for Vista & 7.
Thanks this worked, it was taking up like 40GB, reduced it to 3GB.
1 - 12 of 12 Posts
