I just installed W7 in my new build so I can re-install W7 if needed.
Computer management shows the HDD's not populated, so I click the populate button, then whenever I click okay and come back into the same screen it says the drive isn't populated.
BIOS and Disk management shows the drives but these are the only options I have from Disk management. I tried looking around and haven't found anything, sorry if this has an easy solution that I should've seen earlier.
Currently using AHCI for the drives, I had the same problem with just IDE before.
