1 - 12 of 12 Posts
I have my phone, and a memory card in it. i have a program that turns it into a flash drive so no phone drivers need to be installed. im using my linux computer and when i try to open the drive it wont let me... it says<div style="margin:20px; margin-top:5px; ">
<tr>
Could not mount the device The reported error was: mount: wrong fs type, bad option, bad superblock on /dev/sda1 Missing codepage or other error in some cases useful info is found in syslog - try dmesg | tail or so
</td>
</tr>
</table>
</div>
Daves not here man
Interesting, my phone has a 1gb micro sd that i can take out and use a usb adapter to transfer files, when i had my samsung a900 i could never get linux to reconize it
Daves not here man
FAT is supported in linux
Daves not here man
I'm sure someone with more experience in cell phone storage and linux support could shed some light on this
What does the command: "dmesg | tail" say?
<tr>
<div>
Originally Posted by <strong>geekedittilitghz</strong>
</div>
<div style="font-style:italic">I have my phone, and a memory card in it. i have a program that turns it into a flash drive so no phone drivers need to be installed. im using my linux computer and when i try to open the drive it wont let me... it says</div>
</td>
</tr>
</table>
</div>you have to have the vfat filesystem kernel drivers either loaded as a module or built into your kernel, in order to mount a fat16/32 filesystem.<br />
<br />
then, you may have to explicitly SAY you want vfat.. by default the gui way is to use fs=auto<br />
<br />
(IMPORTANT! if ALL of your hard drives are ata then your phone, when plugged in via usb, will be sda1 or sdb1 meaning scsi device either 1st or 2nd, usb uses generic scsi emulation or something like that)<br />
<br />
(and make sure you make the mountpoint /mnt/phone by doing #mkdir /mnt/phone)<br />
<br />
so try (as root)<br />
<br />
#mount -t vfat /dev/sda1 /mnt/phone<br />
<br />
<br />
<br />
if you get an error saying that device does not exist, try sdb1 sdc1 sda2 sdb2 etc.. idk your configuration, dmesg tells you though, and you haven't posted it <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
and if you STILL can't mount it, you might not have vfat built into your kernel, or loaded... try #lsmod see what popps out... <br />
<br />
<br />
if no message is displayed at all.,.. then check /mnt/phone and look at your contents!!! yay.<br />
<br />
<br />
<br />
hth
1 - 12 of 12 Posts
