Hey guys, I'm finally getting around to my build after having packaged parts sit on my bench for over a month! I've ran into a bit of a snag and would like some routing ideas.
What I've got here are 2 EVGA Titan X Hydro Copper's on an EVGA X99 Classified motherboard and in the last slot you can see an Intel 750 Series PCI SSD with EK waterblock installed. Clearly the ports don't line up like I want them too. I don't think I can get away with using T's here because of flow problems that could arise. Also don't want to move away from this slot configuration as it uses the lanes the best. The only solution I can think of is hope EK makes a bridge with 6 holes (I would cap the 2 closest to the card) where I can run into the top (stage front) then out the bottom (into the rads on the left, back to the pump on the right). Your suggestions are welcome.
