1 - 11 of 11 Posts
Just finishing up my latest build.
Asus Sabertooth Mobo
Fx 9590 CPU
Zalman Reserator max 3 Nano Cooler
16 GB GSkill
MSI R9 270x
two of them that im currently trying to crossfire.
Corsair HX 1050 PSU
So I had everything running fine. installed the lastest drivr using the CCC.
I had the graphic cards crossfired and working. played around one hour of Assassin Creed on high settings. Game Locked up and Froze.
After that I kept getting blue screen. Did a System Restore to an earlier point. just a few hours before.
Now it didnt not notice the second GPU.
I removed the second card restarted, then Re installed the second Card and nothing. This is where I am at now. Might try to Unistall the drivers install both cards and re install drivers ?
What do you guys think?
Thanks
pass the lortabs
Did you check if you need to reenable Crossfire in CCC?
pass the lortabs
Reinstall the driver.
I would go one step further and uninstall the existing driver package and deep clean. Then reinstall the gpu driver package.
pass the lortabs
Absolutely, that should be standard practice.
Reactions: AriGold787
ok thats exactly what i did and worked. but now i seem to have a black bar around my screen. just need to change resolution or what?
not the best with software stuff I need to read more and learn more of this.
Thanks again
pass the lortabs
Check for the overscan setting in 'digital flat panels', I think.
Discussion Starter · #9 ·
had to switch to standard view but got it thanks ! seems to be working good now.
any advice to make corssfire run a little smoother? I have afterburner and msi gamming app that will adjust the some speeds.
pass the lortabs
You can bump the core clock up for some added performance.
What resolution is your monitor?
Also, don't perform a System Restore the next time you blue screen; make a thread here and try to figure out why you crashed and how to fix it.
Discussion Starter · #11 ·
Will do, I panicked like it was black friday and i was in walmart.
1920*1080
75hz
Asus
its a little older. might upgrade next
1 - 11 of 11 Posts
