1 - 6 of 6 Posts
I use a Logitech G11 for the last 3 years but keys are beginning to get stuck. For example if i pres the corner of the left CRTL key it goes down 1mm and then gets stuck.
Is there a remedy for this? Is it physical damage or it just needs some lubrication?
Thank you
3 years sounds about right for the lifetime of your typical cost reduced modern rubber dome keyboard.
If I get 5 years out of my $300 Topre I'll be happy.
1 - 6 of 6 Posts
