Whoopass, welcome to OCN
I noticed you mentioned your memory is sitting at DDR2 960. That means your memory is running at 480Mhz which is about 80Mhz overclocked from the factory 400Mhz. This might be the cause and limitation of your current OC. Having overclocked memory can sometimes cause stability issues. I'd suggest running a lower memory frequency (lower the divider) to see if that helps. Try DRR2 667 to see where that puts you. Making changes to your memory can be done within the BIOS under Cell Menu->Advance DRAM Configuration. Change DRAM Timing Mode from Auto to Manual and see if that provides any additional options. Sorry I wish I could help you more with that but your manual isn't exactly informative. Perhaps someone else with this board can pop in and help.
I'd also like to note that the Phenom 9500 was one of the first Phenom processors that came with the TLB bug (translation lookaside buffer). This was plagued in the first version of the Phenom processors (9500/9600). Overclocking is a bit difficult with the existence of this bug. The B3 stepping later on fixed this problem and made overclocking a bit more friendly. If you do want to push your processor more, please disable any options in the BIOS that are related to "virtualization". Look under CPU Feature->SVM Support. Please disable that option. I believe this is where the TLB bug showed it's evil colors.
If you can please add your system specifications to your signature. This is extremely helpful to me and other members. You can do this by going here: http://www.overclock.net/specs.php?do=addsystem.
Don't hesitate to ask more questions
Good luck
Good luck
