1 - 3 of 3 Posts
Can you test something? If you undock the laptop, so just the power cable is connected, does the power LED and "release" switch stay illuminated blue?
I had one dock break, they sent me another but it displays the exact same issue. I'm trying to figure out if the dock has power to it or not, because the lights never turn on!
My dock at work stays lit as long as there is either power or a laptop connected IIRC...
That's with the ePort Plus and a Latitude E5550
That's for the release button.
Cool, that's what I thought.
Can you check at work tomorrow and send me a whatsapp pic? I want one to send to Dell. Because I work at home I have nothing to compare against.
1 - 3 of 3 Posts
