Has anyone heard of this X-Fi card?
477 Views 8 Replies 8 Participants Last post by  smitty5569
http://www.epartsandmore.com/product...ase#googlebase
I bought one from this site. Seems like a really good deal for an X-Fi XtremeGamer. Has dedicated 3.5 mm jacks and two optical ports as well. I've never seen this card on newegg or any other site besides a select few. Has anyone seen this card?
1 - 9 of 9 Posts
that used to be my old sound card iirc from my old Dell
Is it a good card? Or did I just get a bad deal.
it's a great card, it's definitely a step up over the current xtreme gamer cards because that has optical in/out and the extra channel input over the current model. in terms of technical specifications pretty much all of the x-fi cards are "same ****, different name". the differences are minute and pretty negligible.
Same as extreme gamer. Just a bit bigger and a few bells and whistles added
pretty nice upgrade from onboard imo
I think the price is so low because they are refurbished sound cards. Not sure what you had before this card but I'm sure it'll sound better.
I have the fatality version of this card and it's an amazing card! If you've never had a X-Fi card before you'll be extremely impressed.
1 - 9 of 9 Posts
