1 - 2 of 2 Posts
Alright I have been creeping on many build logs for quite some time now and am completely wanting and willing to dive into water cooling my computer. I have never done this before so obviously I am completely new to it and ask for your patience which has never been a problem in the past. To be honest I have never even seen a water cooled computer up close and personal. Anyways, my current plan is to switch into either an nzxt phantom 01 or 630 or the switch 810. As of right now I am super close to pulling the trigger on the switch 810 case as I have heard these are very friendly to those looking forward to water cooling. Now, I have been reading quite a few threads on WCing but as you can imagine it is all very foreign and reading the terminology can only do so much for me.
I would like to keep it simple for now and limit my "loop" to just the cpu but am completely overwhelmed when it comes to selecting components as there is a dizzying array of choices. From my very limited understanding I need a pump, reservoir, radiator, and cpu water block...is this correct? Also, how many rads do I need? It seems like a lot of people refer to two rads when they talk about their loops but as I am only needing to cool the cpu I'm not sure? For reference I have an AMD cpu and 600w psu. I know this is very vague and limited but that's pretty much where I am as of right now...
Oh and this is a bit off topic but what's the deal with the WC bundles like the Raystorm 750 RS240 kits..they are only $150ish are these worth it...or do you recommend making my own loop from custom parts?
Anything that will help me get started and make a purchase is greatly appreciated and I can't wait! Thanks in advance.
Welcome to water cooling!!
XSPC kits are very good start. They have solid parts and even the cheaper ones are good enough to cool a single cpu. Downside is that you have no choice on details like fitting, tubes and reservoir. I think aesthetics is what people value as much as performance in water cooling. If you don't care about those details, just go for a kit. Also, you might miss the excitement of picking up parts on your own
Based on my own experience, you're very likely to want your gpu water cooled soon. So I highly recommend XSPC kits with a 360mm radiator. (Switch 810 can accommodate the rad)
1 - 2 of 2 Posts
