In light of the recent deaths of 570's, I'd like to gather some information to keep others from killing theirs!
Please fill out the following if yours died. Also please include a picture if you have one:
User:
Core Voltage:
Clocks:
OCP/Power limit disabled: (Y/N)
Load Temperature:
VRM Cooling:
What you were doing: (Gaming, benching, stress testing)
If you'd still like to purchase a GTX 570, I urge you to get one of the following:
http://www.overclock.net/nvidia/928291-disabled-power-limit-occt-fried-gtx-2.html#post12209267
http://www.xtremesystems.org/forums/showthread.php?p=4727355#post4727355
http://www.overclock.net/nvidia/914105-gtx-570-dead.html
User: xxbassplayerxx
Core Voltage: 1.212V (1.223 with DMM)
Clocks: 1100/1200
OCP/Power limit disabled: Nope!
Load Temperature: -40C
VRM Cooling: Stock unisink / cold from phase / fan
What you were doing: Running Vantage Performance
User: jonjryjo
Core Voltage: 1.1v
Clocks:900/1800/2100
OCP/Power limit disabled: Yes via /GTX500OCP gpu-z argument.
Load Temperature: 58*C, it never went above 45 with power limit enabled.
VRM Cooling: DDGTX580
What you were doing: OCCT
User: slickric21
Core Voltage: 1.05
Clocks: 880/2000
OCP/Power limit disabled: Yes, via GPUZ 1.5.1 & /GTX500OCP
Load Temperature: 44'C
VRM Cooling: Accelero Xtreme VR sinks (+2 extra 120mm fans blowing on them)
What you were doing: OCCT GPU, full screen/complexity 8.
User: kerrk
Core Voltage: 1.2v
Clocks: 920/1840/2200
Load Temperature: 70 C
VRM Cooling: Stock
What you were doing: Benchmarking with 3dMark 11
User: rancor
Core Voltage:1.100(After burner)1.034 GPU-Z
Clocks:875/1750/2000
OCP/Power limit disabled: Yes (Hit 105A in GPU-Z)
Load Temperature: 80
VRM Cooling: Stock
What you were doing: Furmark stress testing
User: mistkron
Core Voltage: 1.100
Clocks: 900/1800/2000
OCP/Power limit disabled: No!
Load Temperature:
VRM Cooling: Twin Frozr II Unisink
What you were doing: Unigine Heaven
User: Shredicus
Core Voltage: Unlocked to 1.2v was around 1.17 at the time
Clocks: 980/2200 - 920/2000
Load Temperature: 70c
VRM Cooling: Stock
What you were doing: Crysis
User: miahallen
Core Voltage: 1.2V via MSI AB v
Clocks: 950/2200
Load Temperature: ??? (fan @ 85%)
VRM Cooling: Stock
What you were doing: 3DMark Vantage
User: Pr0paIn
Core Voltage: 1025 mv
Clocks: 870 Core / 2075 Memory
Load Temperature: 74-76 Celcius
VRM Cooling: Stock
What you were doing: CryEngine 3 Sandbox
User: Basti51
Core Voltage: 1050mV
Load Temperature: 60°C
VRM Cooling: AXP
What you were doing: Gaming - Mafia 2
User: kenan435
Core Voltage: 1100mV
Clocks: 920/1840/2000
Load Temperature: 76°C
VRM Cooling: Stock
User: Scorpion667
Core Voltage:1.1v
Clocks: 920/2000
OCP/Power limit disabled: never
Load Temperature: 76c
VRM Cooling: stock
What you were doing: haven 2.1
User: Riou
Core Voltage: stock
Clocks: stock
Load Temperature: 72C (Mirror's Edge)
VRM Cooling: stock
What you were doing: Browsing Overclock.net
User: whipgeez
Core Voltage: 1.038
Clocks: 850/2000
Load Temperature: 77c
VRM Cooling: Stock
User: McDown
Core Voltage: 1.1v
Clocks: core 935, mem 2000
Load Temperature: 80C
VRM Cooling: stock
What you were doing: (Crysis 2, 270.51 Beta driver)
User: Officer Farva
Core Voltage:1.1v
Clocks: 900/2000
Load Temperature: 66
VRM Cooling: stock
What you were doing: Crysis (So no, it couldn't run it )
User: Chris Ihao
Core Voltage: 1.1V
Clocks: 890/1000
OCP/Power limit disabled: No.
Load Temperature: sub 80c
VRM Cooling: AC Xtreme Plus (VR004 sinks)
What you were doing: Shogun 2 with depth of field enabled. Wicked hot.
User: AzN1337c0d3r
Core Voltage: 1.05V
Clocks: 825/2200
OCP/Power limit disabled: (Y/N) N
Load Temperature: ~85
VRM Cooling: Stock
What you were doing: Furmark, boom after 20 seconds. Rebooted to Windows fine, would power off system when trying to launch 3D game.
User: AzN1337c0d3r
Core Voltage: Stock
Clocks: 850/2350
VRM Cooling: Stock
What you were doing: Furmark, boom after 5 seconds. Would not POST after.
User: Born2bwild
Core Voltage: 1.100 V
Clocks: 920Mhz/2200Mhz
Load Temperature: 82*C
VRM Cooling: Stock, plus two 2000rpm 120mm fans blowing on the SLI stock
What you were doing: Crysis 2
User: bleda76
Card: Gigabyte GTX 570 OC (GV-N570OC-13I)
Core Voltage: 1.00V (factory default)
Clocks: 850Mhz core /2250Mhz memory
Load Temperature: 65-67C
VRM Cooling: Gigabyte Windforce x3
What you were doing: Furmark (3 minutes)
User: El_Capitan
Core Voltage: Stock 963mV
Clocks: Stock 732MHz
Load Temperature: Unknown
VRM Cooling: Stock
What you were doing: Playing StarCraft II
User:
Core Voltage:
Clocks:
Load Temperature:
VRM Cooling:
See these threads for more information:Originally Posted by bleda76
-Gainward 570 Phantom, Gainward 570 GS Goes Like Hell, Palit 570 Sonic Platinum all have 8 phase VRMs (6 GPU and 2 memory). Same amount with the GTX 580. All these cards have identical PCB since they belong to the same graphics card manufacturer group
http://images.bit-tech.net/content_i...phantom-1b.jpg
- Asus GTX570 DirectCU II also has 8 phase VRMs (6 GPU and 2 memory)
http://www.techpowerup.com/reviews/A...ages/front.jpg
Clocks: 1100/1200
User: jonjryjo
Core Voltage: 1.1v
User: slickric21
Core Voltage: 1.05
Clocks: 880/2000
User: kerrk
Core Voltage: 1.2v
VRM Cooling: Stock
User: rancor
VRM Cooling: Stock
User: mistkron
Core Voltage: 1.100
Load Temperature:
User: Shredicus
VRM Cooling: Stock
User: miahallen
Clocks: 950/2200
VRM Cooling: Stock
User: Pr0paIn
VRM Cooling: Stock
User: Basti51
VRM Cooling: AXP
User: kenan435
VRM Cooling: Stock
User: Scorpion667
Core Voltage:1.1v
Clocks: 920/2000
VRM Cooling: stock
User: Riou
Core Voltage: stock
Clocks: stock
VRM Cooling: stock
User: whipgeez
Core Voltage: 1.038
Clocks: 850/2000
VRM Cooling: Stock
User: McDown
Core Voltage: 1.1v
VRM Cooling: stock
User: Officer Farva
Core Voltage:1.1v
Clocks: 900/2000
VRM Cooling: stock
User: Chris Ihao
Core Voltage: 1.1V
Clocks: 890/1000
User: AzN1337c0d3r
Core Voltage: 1.05V
Clocks: 825/2200
VRM Cooling: Stock
User: AzN1337c0d3r
Core Voltage: Stock
Clocks: 850/2350
VRM Cooling: Stock
User: Born2bwild
User: bleda76
User: El_Capitan
VRM Cooling: Stock
