1 - 11 of 11 Posts
When I'm in game, CS:S for example, and in vent at the same time, my game goes through vent clear as if the others are playing it themselves. Updated to the newest drivers. Anyone else heard of this happening?
I'm not sure I follow...
Ok, like, if I'm in game, and I push-to-talk in vent, they can hear my games perfectly. almost like I'm playing them into vent, but I don't have it set up that way at all. I dont have speakers, so they shouldn't hear anything but me. Know what I mean?
Oh I see. What you probably set your record on is 'What You Hear'. I should be Microphone instead.
Discussion Starter #5
nope, lasher and i already discussed that. thats not it
Could the sensitivity be set all the way up on the mic, so it picks up on everything?
Maybe Vent use different Record control, check Config see if you find anything. Good luck!
Discussion Starter #9
I've checked EVERYTHING.
Does this look like something a bad card would do?
Discussion Starter #11
http://www.ventrilo.com/faq.php#sound7
Read the one about Half life based game (Source).
Unfortunatly, it's not just source games doing it. It's everything that I hear going through my speakers. They don't really appreciate it since my brand of music is a bit more.......eclectic than others, lol.
This sucks. The card is freakin' sweet in every other way. Sound is so clear I can't believe it. I've already uninstalled and re-installed the drivers too
1 - 11 of 11 Posts
