1 - 20 of 21 Posts
THIS IS NOT A TROLL THREAD.
AND I NEED ANSWERS ASAP I HAVE A POWERPOINT AND A PAPER DUE TOMORROW AND I CANT HAND IT IN LATE!!!!
i just bought a Galaxy GT210 for my mom's PC off of newegg, and took out my 8800GT and put it in mine.
when i installed new drivers for the GT210, it boots up, and reaches the user account screen in full 1920x1080 res, but when i go into ANY account, it says 'input not support' on the monitor! *** is this happening?
i did driver sweeper and wiped them in safe mode and installed the 256 drivers and its still happening!
im using my AOC F22 monitor on my mom's PC. is it the GPU, drivers or monitor?
im using DVI input btw
this is her specs:
ASUS A8AE-LE OEM board
Opty 170
2.5GB DDR ram
GT210 (obviously)
Originally Posted by LethalRise750 View Post
Try going into Low Video Mode via hitting F8, and setting the resolution manually through that, then reboot.
i already did that
and it didnt work.
last known config didnt work either. system restore failed too
Discussion Starter #5
Originally Posted by MR KROGOTH View Post
is it an SLI or multiple pci-e16x board, install through that, and lower the res to like 1024/768 or whatever and boot from there, raise as needed.
no its a OEM mobo from an HP compaq presario
PCIe 1.0 also
the only windows i can boot into is safe mode
Discussion Starter #7
What..? If you hit F8 it should give you something like this:
And just select Low Resolution Video.
my b, i did a quote fail...i quoted u twice, lol
i did that and it loaded to windows, but when i selected an account, the screen went blank and windows rebooted, and the monitor didnt come back on after that! i had to restart it manually by pushing button
lol That's even weirder since the Bios POST screen uses the same resolution (640x480)
Discussion Starter #9
yeah i know! its so strange!
in all of my 13 years of PC experience, this has never happened before!
Discussion Starter #12
Try the 8800GT???
thats going in my PC.
but i guess i could pull it and put it in this mother
besides, my TIM on my PC needs to set....
i hope it works!
*turns off mom's PC*
Discussion Starter #13
CATASTROPHIC FAILURE!
I PUT IN THE 8800GT AND I GOT NO DISPLAY WHAT SO EVER!! I PUT IN MY 8600GTS AND STILL THE SAME PROBLEM! NO DISPLAY!
I PUT IT IN MY SIG RIG AND I GET THE SAME PROBLEM!! *** ARE ALL MY GRAPHICS CARDS DEAD? WHAT THE HELL IS HAPPENING????
i tried it in all of my ch4's slots and same problem! 8800GT, 8600GT and GT210 dont work in my CH4 OR my mom's oEM mobo! they all worked fine before!!!!
i stitched monitors and same issue! changed DVI ports and same problem!
and my CH4 doesnt even POST! it turns on, all the fans spin up, but i got no beep for POST or anything! the monitor stays on with a orange light!
ON BOTH PCs!
WHAT IS HAPPENING???? im panicing and my **** is due tommorow! I DoNT WANT TO FAIL!!!!
Discussion Starter #15
Its sounding like your monitor honestly.
my monitor?
I HAVE 3 MONITORS AND TRIED THEM ALL AND NOTHING IS WORKING! NO DISPLAY ON ALL OF THEM!!!
ONLY A ORANGE LIGHT ON THE PWR BUTON!
k Then it sounds like a possible bad slot =P
Most likely
Dont you have onboard video?
Discussion Starter #18
Originally Posted by dominique120 View Post
Most likely
how is that possible?
BOTH motherboards having bad PCIe slots?
and my CH4 has 4 of them!
my 890FX CH4 doesnt.
but the OEM does i'll try that xpress 200 IGP it has.
Discussion Starter #19
the IGP and the GT210 works in the OEM mobo!
BUT
i get the same 'unsupported resolution' thing with BOTH OF THEM.
on DIFFERENT MONITORS.
idk whats happening.
ALSO
my sig rig (ASUS CH4) doesnt even detect GPUs in the first place! i turn it on and the GPU fan goes on 100% load and i get NO display and NO post beep! i cant get in to bios because i cant SEE anything! the prbablility of all my cards being dead is false because they work, just not in my ASUS crosshair!
does the CH4 even support nvidia cards? i dont have any ATi cards anymore.
what is going on?
1 - 20 of 21 Posts
