My rig is running stable at 350x10.5
I am trying to get to 533x7
Here is what I have done so far:
411x9 boots and seems to run stable.
436x8.5 boots all the way into Ubuntu then starts to act up. When ever I do something graphics intensive it craps out. Funny thing is it does not always crash all the way. Sometimes it just kills whatever window you just opened. Othertimes the graphics go all crazy. It does the same thing @ 463x8.
Does this sound like a problem with my graphics card? Or have I missed a setting in my BIOS (maybe need more volts for the NB?)
Here are my settings:
CPU Ratio 8
FSB 436
PCIE 100
FSB Strap to NB auto
Dram freq 872
Dram Timing auto
5-5-5-15-3-54-6-3
8-3-5-4-6-4-7
14-5-1-6-6
Dram static read Disabled
Dram Read training Disabled
Mem Oc Charger Auto
AI Clock Twister Auto
AI Transaction Booster Auto
CPu Voltage 1.375
Cpu Gtl ref auto
Cpu PLL volts 1.50
FSB term volts 1.14
dram volts auto
NB volts 1.24
SB volts auto
PCIE sata volts auto
Load Line Calibration enabled
cpu spread spec disabled
pcie spread spec disabled
cpu clock skew standard
nb clock skew standard
cpu margin enhance optimize
C1E support disabled
max CPUID Value disabled
CPU TM funct Disabled
Execute Disable Bit Enabled
CPU Ratio 8
FSB 436
PCIE 100
Dram freq 872
Dram Timing auto
5-5-5-15-3-54-6-3
8-3-5-4-6-4-7
14-5-1-6-6
Mem Oc Charger Auto
CPu Voltage 1.375
Cpu Gtl ref auto
Cpu PLL volts 1.50
FSB term volts 1.14
dram volts auto
NB volts 1.24
SB volts auto
