Did you check your RAM? You want to make sure that is perfectly stable. Also, maybe up the vcore a little bit (although I wouldn't recommend much more than 1.6). Try upping the RAM voltage, too. I don't know why, but for some reason that always helps me with to OC.
At full load it's only running 35C don't really worry about temps ram is fine i ram memtest and it came back ok. Ran doom3 for two hours and it was fine no worries.
1 - 4 of 4 Posts
