HD 5850 crossfire or one HD 5970?
24703 Views 28 Replies 22 Participants Last post by  Slayem
Two HD 5850s are slightly cheaper than a single HD 5970 while two HD 5870s are much more expensive than one HD 5970. Since the HD 5970 has a dual GPU there is the problem with micro stutter and I would need to invest in a big tower to fit that huge card in. I really can't decide.
So either Two HD 5850 in crossfire or a single HD 5970 or maybe even a single HD 5870 and add a cheaper priced one later?
The computer will be a build around a core i7 920 with at least 6gb RAM.
Thanks.
1 - 20 of 29 Posts
If you can afford it, I'd go for 1 5970 now and another next year.
My vote goes for the 5970, it's right smack in the middle of 2x 5850's and 2x 5870's in terms of performance. Fastest card in the world son.....hell yeah
Also micro stutter would be a problem any time you have a multi-gpu setup, regardless of whether or not its all on one pcb (card) or two pcb's
Two 5850s, in my opinion.
You don't need more power than that for ANY game.
hd5970 is the best choise
Isn't the micro stutter a significant problem with the HD 5970?
no, its just a minor problem with all multi-gpu setups. its not simply limited to the 5970
5970, as "microstuddering" would be less, than with 2 5850s.
5970. It's basically a down clocked 5870 CF.
Basically,2 5870s GPUs, that are clocked down to comply with PCI-e 1.0/Wattage, so that ATI can still target all PCI-e markets.
In terms of performance 5970 will be a bit faster but only about 1-2fps in most games. 160SP don't make as much difference as many people think. Also the 5850 run a bit cooler because they are 2 cars so they will overclock a bit more and ending up faster then HD5970. Personally i would get a 5970 because when you are ready to sell it you will get like 300$ but for the 5850 you would be lucky if you get 250.
Thats bad reasoning, here's why: the 5970 would be over $600 to buy right now. If he sold it for $300 he would be out $300 or more. If he got a 5850 and sold it even for $200, he would only be out $100
Will you just buy something already....
Look at it this way. The 5970 no matter what lowest it will go is 350-400 even after 1 year. That will sell 275-300 used. A 5850 will go for 125-150 and will sell for 100$. Look at 4870 vs 4870X2. It cost more to get a 4870X2 then 2 x 4870.
Don't assume such a huge pricedrop for the 5970.
Fermi at the moment is nothing.
I don't expect them coming with anything beating the 5970 soon.
Demand is high.
Availability is lacking.
Prices will remain high.
What resolution are you gaming at? If you're just at 1680x1050 or 1920x1200 pickup a 5870 now, and xfire later when the price drops. You get plenty of performance for most anything now, and you have the perfect upgrade path for the future.
I really enjoy overclocking, and the problems getting the most out of the 5970's (VRM temps) kind of takes the fun out of that. Yes, it's not really an issue with actual games as of today, but in the future some games may stress just as much as the benches which are causing the problems. I'd be much happier personally getting xfire 5870s to see the max the chip can do.
I am at a similar dilemma as the OP. I would also like others input on this matter. I bought 2 HD5850 from Amazon when they were out of stock for approx $270 each (amazon is still out of these). Together its about $540. Right now, the 5970 are selling for about $650. The difference is over 100 so my question is do you guys think I should drop the 2 5850s and get a 5970 or wait? The 5970s are out of stock as well and I'm in no hurry.
I will be primarily be using it for gaming and in high resolutions, 1680 and above.
The question really depends on what system the OP has and his intentions/screen size/case really. CF 5850's will definitely stand their ground in every game out there if he runs them on an i7 rig, for example. So will a 5970. Bah. Conclusion: Doesn't really matter. Both setups kicks ass.
1 - 20 of 29 Posts
