HD 5870 fit in a antec 900 ?
5234 Views 13 Replies 12 Participants Last post by  Bal3Wolf
Looking at getting a new video card and i was looking at the HD 5870 and HD 5850 wondering if those would fit in a antec 900 case ?
1 - 14 of 14 Posts
yeah a 5870 will fit inside an antec 900 no problem. you should be good to go
A 5850 will certainly fit without much struggle, but a 5870 might give you some trouble, depending on the wiring. Worst case scenario you'll not be able to use (maybe even need to remove) the HDD bays right behind it.
IIRC the 5870 is ~11", and the 5850 is about 9.5".
Here's your case, and I believe the measurement is correct:
I'd say it's worth it
it'd fit, but you cannot but HDD's in the middle HDD cage. good luck!
My watercooled GTX295 fits no problem. Kinda tight but it works. HD5870 is shorter so there's no doubt it will fit.
Thanks wont be buying it till after xmas probly cant find them in stock now anyway i wonder if a 680 watt psu will be enugh for it and my quad.
I had a second fan in the back of the middle hard drive bay. I had to take it out to fit the 5850.
Originally Posted by skitzogreg
Fits w/ extra space.
Edit: That thing is so closed to the cages ;o
Originally Posted by dudenell
yes but you will not be able to put a hard-drive at that slot(s)
i can fit the 5870 and the hdd
Yeah, another thing that makes it easier is if you move the cages out a little bit so they are flush with the front bezel.
lol funny someone bumped this from 6 months ago but they fit just dont have a hd inline with the 5870 or your gonna have problems.
1 - 14 of 14 Posts
