1 - 4 of 4 Posts
Hey guys, i got a question i have a HD 7850, and i wanted to know would there be any difference in using a HDMI to Dvi adapter as my screen only supports a dvi port, will there be any difference?, or will it be just the same..i can't afford a full hd monitor right now so thats why im asking?!..
Thanks!
· Premium Member
Depends on where you live, sounds like the UK. In the US, newegg.com gives us some of the best deals but I would guess amazon would be a good place to look for you.
Asus has some of the best bang for your buck monitors right now, I would look there.
1 - 4 of 4 Posts
