I believe that all current games on the PC are HD..
I mean, isn't that all HD is? Higher resolution?
the current HDTV standards are defined in ITU-R BT.709 as 1080 active interlaced or progressive lines, or 720 progressive lines, using a 16:9 aspect ratio |
Originally Posted by J o h n R o g e r s ![]() So, since I run 16:10, it isn't considered HD? Or is it still alright since its bigger than 16:9? |
Originally Posted by Max ![]() does it really matter? as long as your running a high resolution with good contrast and good color, it should end up looking like hd ![]() |
