1 - 5 of 5 Posts
disable memory flexibility on bios,
if that doesn't work, imnot sure right now
got a new mobo mines gone down to 6.6 and yes there is a performance hit,
my mobo hasnt got memory flex so i better start fiddling with other crap
This is very normal with ATI cards as others have said. I posted the same question when I first got my 5870. It is just because they downclock when not in high use.
I remember looking at GPUZ and thinking, my card is bad, it is only clocked at 300mhz.
You can run it back to back and the score usually goes back up with no other configuration changes.
BTW, how do you like your card?
1 - 5 of 5 Posts
