HD raid question
755 Views 3 Replies 4 Participants Last post by  gonX
Hi all,
I'm planning on going raid 0 with a new install of Windows 7. I have 2 500 gb, Sata II, 32 mb cache, 7200 rpm hard drives. One is a Seagate the other a WD. Do any of you think I might encounter any problems with doing a raid with 2 drives that are basically identical but made by different manufacturer's?
Thanks in advance.
Yeababy
1 - 4 of 4 Posts
IMO no,as long as they are the same size & speed.
You'll be fine
I'm doing exactly what you're describing on my main rig:
http://www.overclock.net/system.php?i=19780
1 - 4 of 4 Posts
