HD3300 performance?
8057 Views 42 Replies 14 Participants Last post by  rkirkw
This integrated video is what I'm looking to get.
You think it will play Counter Strike Source maxed out at 1440x900 res?
1 - 20 of 43 Posts
I'm using it right now as my 4870 just shipped out this afternoon. I've got it operating at 1680x1050 and have it folding and it operates smoothly. I haven't tried gaming with it but I'm sure it would prolly max out CS.
it can play cs source max settings with no problems! you can also overclock it just in case.
You can always Hybrid Crossfire it with a $20 HD3450 for a cheap boost.
I have tried it with COD4, and it's not really playable unless you set everything to low.
Let's face it, if you wanna game, you gotta get a GPU.
Call of Duty 4 will need a better video card, but it will run CS without any problems, that's sure!
My friend can max out Portal at 1680 x 1050, so you should be fine.
(paired with a PHII 940)
I was able to play COD4 @ 1024x768 @ med settings across the board @ a respectable 45 avg fps. This was at a 2.8 Ghz AMD X2 45W
Anyone else confirm this with Source?
just get yourself a fast cpu and you won't even have to worry about it.
The UD4H is out of stock, so I was thinking the HD3200? How does that compare? Does the 780G support Phenom IIs
hd3300 is 30% faster. plus it has sb750 with acc for better overclocking and enhanced energy efficiency. just go for the 790gx.
Looking at this Foxconn motherboard
Really wanted that UD4H Gigabyte one...and I have to order sometime today.
So are there any other motherboards in the $120 price range? I really want to stay away from Biostar...
yeah that should be fine. or the asus or the dfi one.
rep+ for your help
cheers.
what are you gonna pair it with anyway?
cheers.
Q6600.
Just kidding lol a 720BE. I heard in the Newegg reviews I have to flash the BIOS for Phenom II support!?!
If ddr2 support would be fine, go with DS4H. It's a pretty nice motherboard for Ph II. Mine can run x19,5 multi, many boards don't like more than x18 multi.
I've also had my ds4h running at 233 fsb without instabilities
Q6600.
For a am3 motherboard you wouldn't need to flash the bios.
If you use a am2 or am2+ you will have to flash bios.
1 - 20 of 43 Posts
