1 - 4 of 4 Posts
Code Monkey
Right, basically, I'm a noob when it comes to soldering, and numerous other things
I want to get one of these http://www.watercoolingshop.co.uk/20...ite_AQHKW.aspx
To display system specs, new email notifications, now playing, basically whatever I want, etc.
I understand that this can connect through parallel, and USB too. And can work through a program (LCD something or other, I forgot)
This would likely go in a 5.25" bay in my sigrig. Although I might put it underneath my monitor.
I can't find a tutorial for idiots like myself. Is there anyone here who'#s done this who can point me towards a tutorial? Really want to do this, it seems cheaper than buying a fan controller that has a temperature readout in it.
HD44780 controlled displays are cheap and plentiful, but require a parallel port. You wont be able to hook that up to USB without additional circuitry.
There are devices called 'backpacks' that will connect to your 44780 display and give you a serial port or USB to control it with. this is much easier than mucking with the 44780 directly.
check this: http://www.sparkfun.com/commerce/pro...roducts_id=258
Something like that might be something you could be interested in.
Code Monkey
So, with this "backpack", all I'd need to do is plug that into the display, and then connect up a parallel port?
The one dext3r linked to outputs in UART, which I believe is not compatible with USB, so you can't just hook it up. I spent a few mins trying to find a suitable adapter, but all I could find are DIY microcontroller kits. They aren't hard to do with the right guides, but some technical skill is required. I have a good amount of background with microcontroller, so I might be a little biased on the skill needed. Someone else might know of something that would work with a simple hookup, but I don't see an easy way at the moment.
1 - 4 of 4 Posts
