1 - 6 of 6 Posts
Hey guys , i was wondering how large this card is Length, width, and height, and would it fit in a midi-tower case (HP Pavilion) and would a corsair TX750 power it?
will it fit?
depends on how the front drive bays are
my old a814x case had no drive bays on the bottom half of the front, so i'm confident it could fit a card like that, but i'm not sure about yours
Originally Posted by zomgiwin View Post
will it fit?
ok , thanks for the info anyway
The HD4870 is ~9.5 inches in length (source). I believe the height (of the standard HD4870 cooler) is just enough to cover a second PCI-e slot opening - as in, you won't be able to use the other slot directly below. I'm not sure on the exact width, but it seems pretty standard (width of a normal ATX case PCI-e slot opening) judging from the source I provided.
I'm not sure if it will fit in your Pavilion's case specifically, sorry.
ok thanks alot for that , really helped , i will see if ive got 24cm free for the card , have to check tomorro
thanks again.
DIY Guy
A Corsair TX650 would power it just fine, don't spend those extra bucks if you don't really need it.
1 - 6 of 6 Posts
