HD4870X2 artifacts, please help
964 Views 5 Replies 4 Participants Last post by  Emotional Post-it Note
ok i did mistake i tryed ccc auto tune up so it did speeds 790/990 when i tested it i got artifacts, so seted back to 750/900 but they still is, what i should do next?
1 - 6 of 6 Posts
what is your temp? have you tried to turn the fan speed higher to keep it cool?
ide 67c, i back to stock speed just i dont know get rid off artifacts, reinstall drivers or RMA
67 is pretty high for idle. try to turn your fan to around 50% to see what happen.
If wat he said doesnt work, then try reinstalling the drivers. Don't forget to use drivercleaner.
If still not working then try re-seatting the card in the PCI-E slot by taking it out and reputting it back in.
If all fails, then i recommend a reformat, it can work miracles.
Good advice. It can be a pain, but that is ultimately the course of action I had to take with my x2's. It can happen sometimes, no matter how vigorously you clean the drivers. Try the other options first, of course.
1 - 6 of 6 Posts
