1 - 8 of 8 Posts
Hi guys. For all you HD4890 users, do share the fan speed you are currently using, and the temps you are getting.
Im using a PowerColor HD4890 PCS+ 1GB (the 1 with the zerotherm cooler)
Im running at 55% fan speed, with a coolermaster sticker 120mm fan running at 1400rpm on my side panel blowing toward the card.
Idling @ 47-48 constant. And loads at 75 and near constant 80. Most of the time its 75 though during gaming and artifacts test.
not overclocked. Running at stock 950/1050
According to Everest Ultimate, my memory is idling at 56 degrees. Is it normal?
I have a few question tho'. Is it ok to increase the fan speed to the fullest? Will it damage the card?
What is the maximum temp for this 55nm chip.
PS : Lastly, i notice that the heat-sink is slightly slanted. Just a little, not obvious. I dont know whether it is normal or not. It dosent bother the temps and stuff. Should i stick with the "Do not try to fix something that is working fine" rule?
Do share the temps you are getting too =).
semi-legit
I had a Sapphire reference card.
Usually idled around 42-46c w/ 35-40% fan depending on the ambient temperature / season, memory was around the same IIRC
(your temps are within range so I wouldn't worry
Increasing the fan speed won't damage the card, it could shorten the life-span of the fan itself though (wouldn't worry about it really unless you plan on 100% 24/7 or something).
Also for your side fan; since that card doesn't exhaust out of the case you'd probably get better temps having it exhaust rather than blow air in at the card.
Reactions: Crazy^^Red
Discussion Starter #4
Thanks for the input.
The country i live in is pretty hot. Monsoon season is over, everyday is summer. Damn it. Ambient temps are never good. To make things worst, my air-conditioner is spoiled and im using a fan right now =(
My case fans are limited right now. Ill be getting some Acryans soon. Then i will mount my Silverstone AP121 on my HDD rack blowing towards the card (From the memory area >to> the back) then i will use the side panel fan as an exhaust. Good idea =)
My card runs pretty quiet. Even at 55%, it dosent bothers me. My 120mm fans are louder.
And yes, what happens if the fan dies? Will i need to RMA it? Or get a after market cooler.
semi-legit
Yep, if the fan on that dies you'd need to either RMA or get an aftermarket cooler.
Again I wouldn't worry about it too much though
I have the same cooler as you and same clocks 950/1050 and my card's fan is 32% and in gaming about 50%. Idle temps 41-44C and max temps in games about 61C and in furmark 600 seconds 67C.
1 - 8 of 8 Posts
