HD5970 DisplayPort
616 Views 7 Replies 6 Participants Last post by  Manyak
Does it support direct VGA output (with a simple pass-through cable) or does it need a full blown converter?
1 - 8 of 8 Posts
all you'll need is a dvi to vga converter, those small things came with my 5770, should come with the 5970 too, i don't get what your asking really though, but you'll be able to use vga
Not sure about the 5970 but the 5850 has a HDMI, display port and then 2 DVI ports. I am guessing the 5970 will be the same.
If you want to use the displayport for eyefinity, you'll need an active converter. I believe dell sells one for around $65.
To convert the display port to VGA you need a full blown converter. As said, the DVI will convert with the plain DVI>VGA adapter.
Well that sucks. Oh well, guess I gotta fork up the cash. Thanks guys.
Originally Posted by Digital Artist
My 5970 (Gigabyte) has two (2) DVI outputs. I'm using the white DVI to VGA converter that came with my macbook
No no I'm worried only about the displayport. I have 3 CRTs to run off of it which use analog BNC cables.
1 - 8 of 8 Posts
