Idle, it's sitting at 63c. When I was playing Crysis at max settings (all very high) and shooting that nuclear weapon so many times (no lag), the GPU temps eventually rose to 77c. This is weird because I remember clearly awhile ago, the idle temp was around 40c. But now it's 63c?
Not even overclocked, this is stock. The fan speed is at 31% (according to Catalyst) and there are 4 120mm intake fans on my rear panel, blowing fresh air at the lower part of the mobo, which is where the GPU is located of course. The fan speed is still at 31% when I was playing Crysis.
Is it possible to change the GPU fan speed to 100%? or more than 50% at least. It looks like I can change the fan speed to 100% in Catalyst but then I'd have to enable AMD Overdrive... but what would happen if I enable it? Enabling AMD Overdrive = my GPU will become overclocked?
