1 - 14 of 14 Posts
Hi, I am new to the forums.
Wondering what type of overclocking you can do for a HD6990.
Mine has an EKwaterblock on it.
486
This is what I Have right now.
Is there a certain way to raise the voltage or not? It is already in the higher bios from the flip.
Right now I just raised the clock speed with AMD Vision.
Noooooo! Don't use amd vision. Preferably use Sapphire TriXX or msi afterburner. TriXX is much easier for noobs.
Discussion Starter · #8 ·
Thanks guys, it seems stable, the temperatures are constant, and I am playing COD MW3 just fine. Though I do not really have any other high intensity games to try (crysis is 32 bit, i have 64. darnit)
At 1200 core clock? I refuse to believe it. And 32 bit games will run just fine on 64 bit.
Discussion Starter · #11 ·
Then what are some GPU stress tests?
also heaven v2.0 is a good one but not really good to test the stability test mark is good but does not put alot of load as furmark. tropics is like heaven and for furmark use the multi gpu one
1 - 14 of 14 Posts
