HDD Coolers
1077 Views 12 Replies 9 Participants Last post by  Cyberbot
Whilst looking for case fans to install in my drive bay I came across HDD coolers.
Has anyone used these? are they any good? I assume that they slide over the HDD like a glove. Is that right?
1 - 13 of 13 Posts
do you mean hdd coolers in general,
or did you mean to post a link?
HDD cooling generally isn't needed as the optimal operational temperature is 35-45C. It seems that temps lower than 25C actually reduce life expectancy.
Read: labs.google.com/papers/disk_failures.pdf
DOH !
Here´s me getting the temps down to 22 thinking cooler is better. rep+ for your massive accumulation.
Ps. I´ll read that later,looks like one of my mothers letters 7-8 pages.
just use a fan and dont let it get into the 50C, thats when my drives have died
Originally Posted by iscariot View Post
Just out of curiousity any suggestions as to how to measure HDD temps?
and yes Master Chief I agree they look cool.
HDD have internal temp monitors. Access the SMART data using HD Tune or any thing similar. If you have ACHI or RAID enabled, you may not be able to access the data.
related topic.
got a laptop with dual hdd, get BLAZING hot. burn hands hot. any ideas how to put cooling in a cramped area? it gets hotter over the hdds than over the cpu...
Like Duckie said, HD coolers don't help, and may even be detrimental. Its very unusual to see a hd exceed its ideal operating temp range in a case that isn't, more or less, a giant dust bunny.
This. I just lost my second HDD because of too much cooling
1 - 13 of 13 Posts
