56° is pretty hot, what is your ambient room temperature?
If you can fit it, you might want to have a look at the Kama Bay:
http://www.overclockers.co.uk/showpr...source=froogle
This can be fitted 3 ways, as shown here:
If you decide you like this, you may also like the cheaper option of just buying the kama bay rafter (doesn't come with fan):
If you don't have room for this, yes you can add fan's using velcro or my favorite, cable ties.
Hope this helps.
Hope this helps.
