edit: i probably should have posted this in the hd section... but ya'll are much smarter
somehow my NTFS-3g formatted external drive got owned.
after running test disk and trying to fix the partition table osx goes into kernel panic when i try and mount it, and in linux I get this:
and dmesg says:
wat?
and the files ARE still on it
and dmesg says:
[ 111.483169] sd 9:0:0:0: [sdd] Write Protect is off [ 111.483173] sd 9:0:0:0: [sdd] Mode Sense: 38 00 00 00 [ 111.483175] sd 9:0:0:0: [sdd] Assuming drive cache: write through [ 111.483179] sdd: sdd1 sdd2 sdd3 sdd4 [ 111.487213] sd 9:0:0:0: [sdd] Attached SCSI disk [ 111.487329] sd 9:0:0:0: Attached scsi generic sg5 type 0 [ 112.738556] attempt to access beyond end of device [ 112.738563] sdd4: rw=0, want=1001953808, limit=1001953802 [ 112.738565] hfs: unable to locate alternate MDB [ 112.738570] hfs: continuing without an alternate MDB [ 112.755956] hfs: unable to open extent tree [ 112.755963] hfs: can't find a HFS filesystem on dev sdd4. [ 112.774828] attempt to access beyond end of device [ 112.774834] sdd4: rw=0, want=1001953808, limit=1001953802 [ 112.774838] hfs: unable to locate alternate MDB [ 112.774840] hfs: continuing without an alternate MDB [ 112.776832] hfs: unable to open extent tree [ 112.776838] hfs: can't find a HFS filesystem on dev sdd4. [ 114.444508] eth0: no IPv6 routers present [ 127.172497] hfs: Filesystem was not cleanly unmounted, running fsck.hfsplus is recommended. mounting read-only. [ 127.362843] hfs: failed to load extents file [ 127.381973] hfs: failed to load extents file [ 127.675497] hfs: failed to load extents file [ 127.693756] hfs: failed to load extents file [ 136.278479] attempt to access beyond end of device [ 136.278486] sdd4: rw=0, want=1001953808, limit=1001953802 [ 136.278489] hfs: unable to locate alternate MDB [ 136.278502] hfs: continuing without an alternate MDB [ 136.300867] hfs: unable to open extent tree [ 136.300873] hfs: can't find a HFS filesystem on dev sdd4. [ 136.314991] attempt to access beyond end of device [ 136.314998] sdd4: rw=0, want=1001953808, limit=1001953802 [ 136.315001] hfs: unable to locate alternate MDB [ 136.315002] hfs: continuing without an alternate MDB [ 136.316866] hfs: unable to open extent tree [ 136.316873] hfs: can't find a HFS filesystem on dev sdd4. [ 153.286085] hfs: failed to load extents file [ 153.305215] hfs: failed to load extents file [ 230.714267] attempt to access beyond end of device [ 230.714274] sdd4: rw=0, want=1001953808, limit=1001953802 [ 230.715390] hfs: unable to locate alternate MDB [ 230.715394] hfs: continuing without an alternate MDB [ 230.736780] hfs: unable to open extent tree [ 230.736786] hfs: can't find a HFS filesystem on dev sdd4. [ 230.756408] attempt to access beyond end of device [ 230.756414] sdd4: rw=0, want=1001953808, limit=1001953802 [ 230.757530] hfs: unable to locate alternate MDB [ 230.757534] hfs: continuing without an alternate MDB [ 230.760540] hfs: unable to open extent tree [ 230.760546] hfs: can't find a HFS filesystem on dev sdd4. |
