Originally Posted by
n1helix
Depends on how much you want to spend.
Also depends on whether you want a headset with a microphone built in or nor. If you want a microphone on the headset itself it reduce your choices significantly.
Again, I don't know what you want to spend, but my recommendations would be:
JVC HARX-700 - a decent pair for around $40, you can get a separate mic like a Zalman clip on and be good to go.
Audio Technica ATH-AD700 - a great pair of cans, will set you back around $100, you would need a separate mic with these as well.
Sennheiser PC350 - also a very good pair, these come with a microphone built in, but they run $150.
Like I said, it depends on what you are looking for and how much you want to spend.
