1 - 2 of 2 Posts
What is a good quality headset for xbox live. I have heard the xbox brand ones break really easy. I don't want to spend over 50 bucks, also will regular head sets work with the xbox controller? Any suggestions are appreciated.
Linux Guru
A regular headet would not work for the Xbox because it does not have the correct adapter. I would receommend the PLANTRONICS Gamecom Halo 2 XBox Headset which sells for 41.99 at Newegg, the design seems sturdy and for the prices which other retailers charge for it I think it is a quality product.
1 - 2 of 2 Posts
