Headset/speaker switch
475 Views 4 Replies 3 Participants Last post by  redalert
I found this switch:
http://www.amazon.com/Plantronics-PC...f=pd_rhf_p_t_1
but its a little more expensive than I would like, does anyone know of other alternatives to this that are cheaper?
Also, I am thinking about going with the Sennheiser HD-555 plus zalman clip-on mic but I currently live in a dorm and with the 555's being open how much sound can be heard outside of the headphones?
And finally, what would a similar or cheaper alternative be to the 555's? (either headphone or headset).
Thanks
1 - 5 of 5 Posts
Open headphones don't bleed as much sound as you think.
I have AD700 and when I let other people use them I can't really hear much.
I guess if you're in a library it might be an issue, since its so quite but if there's any type of ambient noise the sound bleeding isn't really noticeable.
The Audio Technica AD700 are a pair of headphones you can look into.
$90, $105 with zalman mic at amazon.
this is the switch im using I got it yesterday and works great http://www.thinkgeek.com/computing/speakers/8054/
Yea, I saw that one while looking around, its just the 'cheapness' look of it kinda worried me. Anyway, from your experience it does work good tho?
Also, +reps
Also, +reps
I had the same feeling about it to that it looks cheap but with no other real options besides paying $35 for the Plantronic one, I decided to go for the $10 and see what happens. No problems at all with it.
1 - 5 of 5 Posts
