Heat Killer Rev3.0 Lga775 Help needed
729 Views 16 Replies 7 Participants Last post by  cooper_inc1
Problem solved ordered the Hk3 but still have 2 questions in mind :
just bought the HK3.0 without backplate do u thnk my old blocks backplate fits it ? cause it has the same holes same spots and 1 last question are connectors on the cpu blocks generally same ?(G 1/4)
1 - 17 of 17 Posts
It should fit, nothing on the block extends passed the 4 mounting points.
Ditto.
dont know whats ditto but i thnk its somethng like "it fits"
thank you guys
Just bought the HK3.0 without backplate do u thnk my old blocks backplate fits it ? cause it has the same holes same spots and 1 last question are connectors on the cpu blocks generally same ?(G 1/4)
if the threads on ur backplate are M4, i see no reason why it shouldn't
what is m4 and do u thnk my old connectors (came with ugly zalman block ) will fit it ? i am using 1/8 pipes thx again ..
99.9% of blocks are made with g1/4 threading and I'm almost certain that zalman is no different so those barbs should fit on the HeatKiller. For any block that is not g/14 threading, I wish the owner the best of luck constructing his/her own barbs and connectors.
P.S. I would recommend going a bit thicker tubing.
It won't fit according to wierdo124, you'll have to ask him why.
Okey than case is closed everyone thx for helping great to be here
---seems not closed yet ---- :
Who is wierdo124 ? and is it connectors or backplate not fitting ?
ditto is that purple slimey pokemon that would copy everything it sees.
ditto also means "same", and the guy who said it quoted someone else who said the right thing
Any site I look is is not giving information on the threading size for the barbs on the zalman. Usually when that is happening its because they used their own custom size instead of the universal standard of g1/4. If that is the case, just pick up some cheap new barbs. I would recommend that anyways as 1/8 tubing is quite small. At least go 3/8.
Same here couldnt find any info about it but it seems like the same cause had another block from Thermaltake it had the same connectors too will see when it arrives if not i ll get new ones
So any other ideas about barb compatibility?
any after market barb you buy will be compatible with the heatkiller. You just have to be careful if you plan to go compression fittings as if the Outer Diameter is 3/4 you will have to get 45 degree angle fittings.
1 - 17 of 17 Posts
